96 Cadillac not getting coolant in engine?
I just replaced the water pump and thermostat. I thought there was relief valve for air but I read there is none on northstars. Could it possibly be a plugged radiator? It sat all winter and I did have water in it but put antifreeze in it before it got cold? The engine will get hot but the radiator wll be bone cold? Any oppinions would be appreciated
thanks
thanks
I just replaced the water pump and thermostat. I thought there was relief valve for air but I read there is none on northstars. Could it possibly be a plugged radiator? It sat all winter and I did have water in it but put antifreeze in it before it got cold? The engine will get hot but the radiator wll be bone cold? Any opinions would be appreciated
thanks
thanks
are your getting heat inside the car when you turn on the heat? if not, coolant level is low.
other than that, thermostat is likely backwards or defective .. pull it, put it in a pot of boiling water and see if it opens.
report back ...
I think I have an obstructed purge, but I cannot find where this is at on the northstar, I have read they are self purging systems. I need some help on this one guys please, the upper tank (plastic) will stay full and will not move.
Showdown
05-12-2014 05:50 PM
leonardo
11-02-2009 06:44 PM
cady97dev
Aluminum Block V8s
03-20-2009 08:10 AM
420Deville
11-10-2007 07:06 PM
