Fleetwood On Air
Hey- I'm new here, just found this site today. I have an 84 Fleetwood that I wan't to bag. Do they make a bolt in kit for my car? How hard is it to do? I would love to see this big car lay frame! Thanks. Joe
[IMG]local://upfiles/4348/CF7BED10943B4876ADAD94A737902CEC.jpg[/IMG] moderator ooppss .. i went into edit instead fo quote .. by mistake |
RE: Fleetwood On Air
ORIGINAL: sanford66 Hey- I'm new here, just found this site today. I have an 84 Fleetwood that I wan't to bag. Do they make a bolt in kit for my car? How hard is it to do? I would love to see this big car lay frame! Thanks. Joe [IMG]local://upfiles/4348/CF7BED10943B4876ADAD94A737902CEC.jpg[/IMG] a great car for dating ... yep. ok .. i give up ... "want to bag' ? |
Bag- as in air bags, air ride suspension. Just wanted info on a kit, or to know if anyone else on here has done this. Sorry for the confusionhttps://www.cadillacforum.com/upfiles/smiley/sorry.gif. Joe
stealth.... lay frame was the clue.......:-) lol i guess you'd have to be there lol
sanford.....nice looking auto........good luck with the bags, i would think you could check your local shops........do you have a son?
rickyd |
Look at this set up - but, it is all custom - you could probably find someone in Kansas City to do this type of work....
Two-pump setup with 8-inch cylinders in the front (with 3-ton chrome springs), 12-inch cylinders in the rear and six batteries. I believe you could ride the rails on this... http://images.lowridermagazine.com/f...front_view.jpg |
GM D-body (Fleetwood, Deville to '84, and Electra) and B-body (Caprice, Parisienne) are all the same as far as suspension parts fitment. The difference isin the springs (when there is a difference) and the longer wheelbase on our D-bodies. Any kit or parts that will fit a Caprice will work, unless there are specific-length lines, in which case longer ones will be needed.
hey sanford66 i own n 89 brougham 4 door with bags on it. i have a 12 gal. tank 2 compressors and 10 switches. i ordered my kit from cce for about 2 thousand with some minor cutting to the uppers if this helps good luck. cadillac pat
