US Emissions Have a question about getting your car to pass a state emissions test? Ask here.
catalytic converter
Old 10-18-2009, 05:31 PM
willieb95's Avatar
Default catalytic converter
can i good use a aftermarket catalytic converter, that works ! and pass emission in ga. 2002 sls Cadillac need by nov 15. thanks code is p0420 low flow ! come on now 1000 members i know someone has tried this and it work come forward please.
Old 10-19-2009, 09:36 AM
92_Daddylac's Avatar
you can use an aftermarket one as long as it is for the car you are driving. all the after market ones do is allow more air to pass through at the same time its doing its job.
Old 10-21-2009, 09:43 PM
sounds like yours is getting clogged .. not uncommon after 7 years .. how many miles?
also, in some cases where the hydrocarbons are excessive, a good muffler shop will install a larger unit .. larger meaning more reactive surface to ignite/burn off the HC's ...
please stick to one thread per subject .. multi posting with the same subject does not help us help you.
Old 10-23-2009, 10:23 PM
willieb95's Avatar
Default thanks
new cat,eastern but code comes on ,so look like I'll be buying the one from the dealer 1000 bucks that's life but thanks again my friend.
Old 10-26-2009, 11:46 PM
99STSGUY's Avatar
got the same eastern cat, code came on a year after had it on car, still works fine thou
Old 10-27-2009, 12:41 AM
i dont see why you must pay any more than a couple $100 bills .. did you take it to a specialty muffler shop? forget the Midas and such chains ...
here in So CA, the toughest emissions State, the muffler shops know what it takes to pass the tests .. they will advice and often guarantee the work to meet emissions standards.
as an example, my Allante had some emission issues, failed SMOG with high Nitrous - took it into the local muffler shop and they decided that the car now needed something a little better than the stock .. cost me $125 plus install .. passed test.
i have no clue what they installed, all i know it passes test.
shops like Midas and such, will only install cats and mufflers by their books .. useless shops when your car needs an extra something.
Old 12-16-2009, 03:39 PM
jesusolorzano's Avatar
I am in Southern Cali, San Diego to be exact, what shop did you take yours if is close to San Diego so I can have them check mine.
Old 12-16-2009, 07:36 PM
its in Los Angeles, way far from SD.
Old 12-17-2009, 12:46 PM
Could you tell me where exactly in LA since my brother lives up there and I usually go up there on the weekends. Thanks.
Old 12-31-2009, 04:09 AM
kevinyoung03's Avatar
Its simply a great car which will give you a great driving pleasure to you.
Quick Reply: catalytic converter
