2006 Escalade ESV
2006 Escalade ESV
Hello: I have a 2006 Escalade ESV. My check engine light went on and as a result I can not get an inspection sticker. I was rejected. Took it to the shop and they told me it was due to emissions and I needed a new gas cap. They replaced the cap, reset the codes and all seemed fine. They told me to drive it 200 miles and then bring it back for the sticker. I needed fuel so I stoped to fill it up. I always shut the engine off and take the keys out of the ignition. When I went to start it to leave, it started very hard and kind of sputtered. After that it started fine. I drove it for about 100 miles and the check engine light came back on. I've noticed that every time I fill the tank, it starts kind of hard and sometimes I even have to push the accelerator down a little to get it to kick in. This has become annoying and I still can't get my inspection sticker. At 100 per hour for the dealer, it's becoming expensive and I'm frustrated. Any ideas on what may be causing the problem.
Thank you for your help
Jake
Jake
Hello Jake. I'm sorry to hear about the issues you've been having with your vehicle. I would like to do what I can for you. I will be sending you a direct message shortly.
Jeff Morris, Cadillac Customer Service
Edit: I tried to direct message you but I saw that you have fewer than 10 posts. I would like to take care of this pivately but the best recourse at this point would be for you to call our Customer Assistance team at 1-800-458-8006. I hope that helps in getting this issue resolved for you. Let me know if you're able to get setup in regards to this issue.
Hello Jeff: I certainly appreciate your quick response. Please direct message me at JakeDrives@comcast.net. I really need a quick fix for this as my rejection sticker is going to expire and I will be left without a vehicle to drive.
If it helps, we've been a GM family for EVER and my Godfather was the Plant Manager at the old Framingham, MA "B" body plant..
Please, lets try and get it done via email...
All my best
Jake
All my best
Jake
