Transfercase Binding 02 Escalade
I have a 02 Escalade that binds/shakes when turning at low speeds in parking lots.The transfer case has been gone thru including the torque clutch assy.I have synthetic fluid in both frt.and rear diffs.
RE: Transfercase Binding 02 Escalade
I have an 02 Escalade that the 4wd system seems to bind up when turning at low speeds. I have had the transfercase rebuilt including the torque clutch assy.And have synthetic fluid both frt.and rear.I have also checked the tire diameter and all tires are the same size and within the 1" rolling test/tolerence.
in my business, when it doesn't do that there is a problem..... i think as they get older and get more miles it gets more pronounced...... on newer ones, its there just not as noticeable...........
