View Poll Results: A poll
50,000 miles - overhauled
6.90%
75,000 miles - overhauled
10.34%
100,000 miles - overhauled
10.34%
150,000 miles - overhauled
3.45%
200,000 miles - overhauled
6.90%
175,000 miles - still going
17.24%
200,000 miles - still going
24.14%
300,000 miles - still going
3.45%
Cost to overhaul $1,500 to $2,500
6.90%
Cost to overhaul $2,501 to $5,000+
10.34%
Voters: 29. You may not vote on this poll
Cadillac automatic transmission life
Old 11-09-2009, 02:14 PM
STSevilleSTS's Avatar
Ive been reading about adding Lucas transmission fix. After reading many forums etc. I am kind of hesitant to add it to a transmission that is showing no problems. Anyone care to give more opinions on this? Like i said my transmission has 160,000 miles on it and is still working fine.
  #12
Old 12-27-2009, 05:02 PM
anypeassiff's Avatar
Default Cadillac automatic transmission life
Um Yes would have to say that isnt safe at all. It could cause damage to the transmission seals and maybe the transmission itself eventually
  #13
Old 04-08-2010, 09:16 AM
ggp8667's Avatar
My 2001 DTS just had the 3rd gear clutch housing redone to include some things that come with the job. ALso had a bad motor mount, and water pump was leaking at the same time, so it also was replaced. All told the total came to $3790. Car has 82,000 on it.
  #14
Old 04-08-2010, 09:49 AM
i'm sorry if you get offended, but that is a irresponsible statement.
even ignoring all claims made by the makers of LUCAS .. we have "rescued" many cars, including many Allante transmissions with the LUCAS fix in the bottle .. a new car has no need for it, a car with mileage can and often shows a great deal of improvement.
most drivers cannot tell when their aging transmissions start to slip .. it is a very gradual change until serious slippage or clutch sticking occurs .. but they sure can tell the sudden improvement after using Lucas, within the 1st 10 miles of driving ...
  #15
Old 04-08-2010, 09:59 AM
if i may ask, what were the symptoms that required the repair?
  #16
Old 08-03-2010, 10:10 AM
f1re93's Avatar
My 4T60-E in my 93 Deville went out at about 129,000mi. total cost for the rebuild was $2056.15 witch is more then i payed for the car but was defidently worth it
  #17
Old 05-02-2012, 06:00 AM
john08's Avatar
ive lost 2 1991 4T60E's around 120-138k miles im in the process of pulling the working car's transmission and having it rebuilt, the working car's transmission wouldnt have went except it had a cooler leak, the lines rusted through and broke off while i was driving so the transmission burned up, my other car's transmission still "works" technically you just have to shift it manually into first to get it to move
  #18
Old 07-30-2012, 06:39 PM
brutis5's Avatar
Default 1999 Deville
My Deville has 190,232 miles on it. one owner. changed fluid and filter every 20,000 mi. only problem is with the speed sensor (the internal part) kicks out code p0503. figured i fix it when it broke. HaHa.
  #19
Old 08-18-2012, 01:33 AM
Antonior's Avatar
I would like to suggest here some versions of Cadillac Automobile Transmission appliances. versions like Deville, Allante are really good as they provide for torque reconstruction.
  #20
Old 02-21-2013, 12:35 AM
LanellePalmer's Avatar
yep i got a sls and mine has 211,989 miles on the car,1 owner.
whitewolf1949
Automatic Transmissions
03-30-2012 03:59 PM
jimsheila
12-12-2011 09:23 PM
ahmaduhhs
04-15-2009 03:04 PM
nobbyneumann
06-14-2007 10:44 AM
simjack
01-09-2005 10:04 AM
Quick Reply: Cadillac automatic transmission life
