Suspension sponsored by Arnott Inc. Discuss anything suspension related within.
"Service Suspension System" -- onboard computer message
Old 07-12-2009, 12:55 PM
johnwilliams's Avatar
Default "Service Suspension System" -- onboard computer message
Hi,
I have a 2001 Seville STS. It has low use with only 65,000 miles.
Just last week, I an auto repair garage fixed a number of things:
(1) replaced A/C compressor
(2) replaced front motor mount
(3) replaced valve cover gasket
(4) replace power steering pressure hose
Now, immediately after the repair, the onboard computer is sending up the message on the dash, "service suspension system." This message never came up before - not once.
Does anyone have any ideas on whether or not:
(a) some of the repair work could have led to this problem?
(b) or what the problem may be?
Thanks in advance for any of your ideas, suggestions, help.
John Williams
Old 03-13-2010, 05:18 PM
codes????? what are the codes please
Old 04-02-2010, 09:03 PM
crimsonpearlsts's Avatar
Default Service Suspension Code
John, what did you find out about your message? I had mine serviced today with motor support replaced and now the message is on.
Thanks, Doug
Old 04-05-2010, 11:53 AM
Adams' Apple's Avatar
Without codes, it's hard to point to a specific cause, but my guess would be someone messed with, or otherwise created a problem with one of the suspension sensors by the passenger side front wheel. The A/C compressor is in the same general area, and the wiring to the sensor may have been moved/damaged while working on the A/C system. The P/S hose replacement would be on the other side(driver side), also, as it would run across the front of the frame from the pump to the rack.
BIGGUYRJ
04-04-2013 11:07 AM
missileJ
05-08-2012 01:28 PM
bsstyle2011
03-22-2011 04:07 PM
CaddyDaddy99
03-25-2010 06:48 PM
ronvalentine
01-20-2008 08:38 AM
Quick Reply: "Service Suspension System" -- onboard computer message
