Suspension sponsored by Arnott Inc. Discuss anything suspension related within.
RSS C1760 current code
Old 12-27-2007, 10:33 AM
Default RSS C1760 current code
plus i get "service suspension system" in DIC..... 99 ststhanks
Old 12-27-2007, 07:21 PM
Default RE: RSS C1760 current code
C1760 Left Front Position Sensor input fault. Being car was just hooked make sure rod is still attached. Rod can normally be put back together if pulled apart.
Old 04-01-2008, 07:02 PM
I have a 1761 which is a right front. I checked the plug, it was clean and attached. What would the electrical test be to determine if the sensor is functioning properly or if it might be shorted.Thanks in advancefor any help
Mike
Old 04-04-2008, 08:40 AM
ORIGINAL: slowroll
gee, sorry i didnt get back slowroll..... rod was broke, as you thought. replaced, and all is well.......... THANKS
RICK
Old 03-11-2010, 11:56 AM
kjasey's Avatar
Default Ricky D
Hi RD. Its been a while. You and i have identical cars and problems I have the RSS 1761 because my rod broke aswell. Ive replaced the rod but still have the code come up. Ive tried resetting the codes etc...do you know where the electrical plug is to check if its clean?
jmk2938
01-18-2009 09:25 PM
CAdMan80
11-28-2008 11:06 PM
jmk2938
05-29-2008 01:49 PM
Jimkana
05-06-2008 11:49 PM
dallascaddy
07-25-2006 11:14 PM
Quick Reply: RSS C1760 current code
