Suspension sponsored by Arnott Inc. Discuss anything suspension related within.
97 sts suspension general info
Old 11-13-2007, 09:20 PM
cleancaddy's Avatar
Default 97 sts suspension general info
does this car have any sort of ar suspension or is there sprngs all around? can I get aftermarket springs if so? My rear looks as if its sits a little too low.
Old 11-13-2007, 09:33 PM
Default RE: 97 sts suspension general info
Springs all around, with shocks with air bags made to them in rear.
Old 11-20-2007, 12:11 PM
cleancaddy's Avatar
Ok so i never hear a pump go on to fill the shocks.....is it something im supposed to hear? is there a way to test it?
Old 11-24-2007, 11:45 PM
Pump mounted on rear suspension cross member. Sensor is small square box with arm made to it and link that attaches to lower control arm.With key in run. Disconnect link and raise arm, compressor should come on. Lower, compressor should quit and air should vent from shocks. Also check for codes.
clok1966
Aluminum Block V8s
11-22-2008 11:30 PM
ballpehler33
10-23-2007 01:32 PM
eechapa
09-05-2007 09:36 PM
04-01-2007 07:39 PM
03-05-2007 08:12 PM
Quick Reply: 97 sts suspension general info
