96 DeVille Rear Shocks
I have a new set of passive shocks for the rear, however the nut on top is so rusted I can't get it to move without the shaft turning also. What would you suggest, cut the old one away or what.
There should be 3 nuts to loosen on top i believe, if you can possibly post a pic so we can see what nut your are having problems with. other wise you could use a dremel and cut it off. just make sure you know the specs of the nut so you can get another one to replace it.
BIGcaddy
03-05-2016 04:42 PM
