Suspension sponsored by Arnott Inc. Discuss anything suspension related within.
95 caddy deville base rear shocks
Old 08-09-2014, 10:27 AM
BIGcaddy's Avatar
Unhappy 95 caddy deville base rear shocks
Air-ride control shocks bad. Is there any other cheaper way to replace shocks? HELP!
Old 03-05-2016, 04:39 PM
john455cid's Avatar
Default rear shocks
If yours is like mine. The pump went bad or lines are plugged. I got a kit from advance auto parts for under 20 bucks. It has a t- valve and airlines and orings and airline nuts. Just unkook airlines from shocks( very easy to do) put new lines on shock , the other ends go to the tee valve. I drilled a small hole ( aprox 1/4 inch ) in trunk for tee valve , so its not exposed to elements. Put 20 ponds of air in. Rides great. No codes show up . air level won't work anymore , but that makes the car corner better anyway . I put strutmaster struts on the front also. Better then stock ride if you ask me.
Old 03-05-2016, 04:42 PM
john455cid's Avatar
Default muffler?
This may sound stupid but have you checked your exhaust for loose parts. Like muffler , shields or clamps?
dross
12-21-2014 03:42 AM
Texan4Life
09-28-2013 09:11 PM
jmk2938
08-18-2009 08:24 PM
allenpinney
06-04-2008 05:32 PM
TJAXFF
10-10-2007 06:57 PM
Quick Reply: 95 caddy deville base rear shocks
