93 STS - Service Ride Control - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 04-05-2008, 05:42 PM
Default 93 STS - Service Ride Control
This seems to be a popular problem with these cars..
Just baught my1993 cadillac sts in December and is nowsaying 'service ride control' sometimes, mainly if i go over a big bump. It also makes some mild clunking and bumping sounds when I drive over popholes etc. I assumed this was normal until reading a post recently. Anyways Igot these codes and could use some further explaining of what they mean:
P013 - Right Oxygen Sensor Not Ready
A048 history - Low Refrigerant Pressure (dont care about this one here)
S011 history - Left Front Damper Solenoid Valve Short to Ground/Open
S055 history - Resistor Module Short to Ground/Open
S062 history - Left Rear Position Sensor Fault
I should also add my front tires need to be changed, they both seem to have slow leaks so I'm constantly filling them up - could this have anything to do with the problem? Or do I probably need new struts/shocks??
-Robin
Old 04-08-2008, 09:26 PM
Default RE: 93 STS - Service Ride Control
You need need new performace based shocks and struts, not cheapies. You may be able to trick car using override in tsb 00-03-11-001A to turn off light. Northstar system not designed to be disabled. Cadillac recommends to keep electronic suspension system on Northstar powered cars, but it will be $$$ to repair.
1995 Cadillac Seville STS service ride control brw Suspension sponsored by Arnott Inc. 1 09-27-2009 02:46 PM
1995 sts service ride control light!! thehock69 Automatic Transmissions 1 03-10-2009 09:17 PM
1996 cadilac devil says (service air ride and airbag light sometimes comes on and also service eng) xpdude Cadillac Deville 1 10-24-2007 09:16 PM
service ride control Big Denny Cadillac Deville 1 10-08-2006 12:11 AM
Service Ride Control message after tire replacement Tiredtech Cadillac Deville 2 09-08-2006 02:28 AM
Tags
00, 93, cadillac, control, damper, front, left, open, ride, s011, short, solenoid, sts, system, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
