Engine mount bracket seems to big
Old 10-13-2007, 03:09 PM
Caddy87's Avatar
Default Engine mount bracket seems to big
Hello everyone. I had a questionI hopesomeone out there could help me with. I have a 87' Fleetwood Brougham that had a Olds 307 in it from the factory. After I pulled the 307 outtoday, I went to install a 94' chevy 350 engine in it I aquired from a chevy van. The motor bolts up to the bellhousing of the 200-4r tranny with no problems, but it seems that the engine brackets of the 350 engine are to big. The motor sits high, only the passenger motor mount bolts up to the frame mountand there is a huge amount of space between the cross member and the oil pan. It seems that I'll need a different set of OEM motorbrackets ,but I have the slighest clue from which vehicle i'll need them from. Is there is anyone out there who can shed some light on this matter?
Thanks in advance
Ronson
Old 10-13-2007, 04:09 PM
Default RE: Engine mount bracket seems to big
To do what your trying you will need 91-92 engine brackets and motor mounts,for engine to sit right,but a 307 sbc is a little small, I perfer some a little larger.I'm non chevy guy, 350+ olds is the easiest but any BIG block will make it roll.Hope it helps
Old 10-13-2007, 04:14 PM
Caddy87's Avatar
Ahh, thanks alot.So what vehicle should I get the brackets and the motor mounts from?
Old 10-13-2007, 04:19 PM
Caddy87's Avatar
The 91-93 Fleetwood had a chevy 350 motor in it from the factory, soshouldI just go to the junk yard and get the engine brackets from one and buy new mounts from the parts store?
Old 10-13-2007, 04:21 PM
Misread your post but you will still need the same parts,not sure if impala / caprice parts will work with your sbc swap
Hauler
04-10-2013 09:03 AM
biglg
11-01-2011 09:36 PM
tonycorvettes
10-29-2008 09:02 PM
akolodny
02-12-2008 06:13 PM
devilleish
Aluminum Block V8s
09-25-2007 06:24 AM
Quick Reply: Engine mount bracket seems to big
