2000 Deville Tire Pressure
Old Apr 4, 2008 | 10:46 PM
Doc Egor's Avatar
Default 2000 Deville Tire Pressure
Sorry to ask a dumb/boarderline repeat question -
My door label is gone and I need to know what the tire pressure spec's are supposed to be for my 2K Deville.
I ran a search on this subject and never did find a thread on my particular year. 30PSI seemed to be the prevailant pressure on newer models.
Can someone with a 2K Deville check their label for me?
Thanks much!
Doc
Old Apr 5, 2008 | 09:03 PM
G.A.R.Y.'s Avatar
Default RE: 2000 Deville Tire Pressure
Don't have the door label info, however, check the side of the tire. Should give you max air pressure.
Your tires are probably not stcck. What is the rating? In any case you can fill tires to max pressure even when cold, and adjust for comfort. Careful not to over inflate or run on low pressure as in either case can reduce life of tires.
Here are some words of wisdon from tirerack.com
Tire Tech Information - Tire & Wheel Owner's Manual
skippyDTS
Mar 24, 2008 03:37 PM
DaveB
Oct 28, 2006 04:51 PM
rjkarizona
Aug 30, 2006 12:27 PM
jsjag
May 11, 2006 01:32 AM
LowGlow33
Apr 20, 2006 12:48 PM
