Diagnostic Codes... What Do These REALLY Mean???
Old 03-19-2007, 09:58 PM
unkut's Avatar
Default Diagnostic Codes... What Do These REALLY Mean???
I pulled the following codes from my '98 Deville today. I then did a search and got these brief and vague descriptions of the problems. Could anyone elaborate on any of these??? I'm having a SERIOUS security problem right now!!! These were all of the current codes.... minus the stupid lost signal ones.
B1910Generator L-Terminal Open Circuit
B1983 Device Power Circuit Low
B2118 Front Vertical Sensor Failed
IPC B2711 PASSKey Open/Shorted Pellet After Good Key
SDM B1126 Driver Deployment Loop Open
TCS U1301 Class 2 Short to Battery
TCS C1255 EBCM Internal Malfunction
TCS C1276 Delivered Torque Signal Circuit Malfunction
TCS U1255 Class 2 Communication Malfunction (Serial Data Line Malfunction)
PZM B2471 Interior Lamp Fault
MSM B0856 Battery 2 Out of Range
MMM B2147 Left Front Mirror Horizontal Position Sensor Circuit High
Old 03-20-2007, 07:19 PM
unkut's Avatar
Default RE: Diagnostic Codes... What Do These REALLY Mean???
Someone PLEASE elaborate on these...... The dealer wants $300 to even begin diagnostics on the car!!!!!
Old 03-21-2007, 11:39 PM
onecool's Avatar
write them all down and then clear them all out and drive the car for a short distance and see wicth ones come up and go from there.
Old 03-22-2007, 01:05 AM
unkut's Avatar
ORIGINAL: onecool
Well I'd LOVE too, but it won't start.....
Old 04-01-2007, 02:11 PM
that is a lot of codes. seems electrical in nature.
i be looking for a disconnected harness connector, dirty grounding straps,
oxidized BUSS connections, loose connectors to computer control boxes
and if nothing there, i be reading the thread that addresses 90% of the problems
we see in our cars: e-ghosts, intermittent, dielectric
https://www.cadillacforum.com/m_6068/tm.htm
get a can of contact cleaner and a can of dielectric grease before you start.
besides, we all should have these two items in our tool boxes at all times.
after 8 years in Ohio, connector oxidation is not unheard of.
a worse posibility is a failed computer box or a shorted wire.
lol
Old 04-01-2007, 09:25 PM
unkut's Avatar
ORIGINAL: Stealth
lol
Well now that you mention it, I'm having all the Security/Electrical problems mentioned in another thread.... so that may be my problem right there! Now, where would I take the car to get a full electrical diagnostics done other than the dealer??? They want $300 to even open the damn door!!! And could you elaborate a little more on the items and locations you mentioned above???
Old 04-01-2007, 10:14 PM
G.A.R.Y.'s Avatar
If and only IF you have a local mechanic that you can trust, he can scan the car just like the dealer and start tracking this down.
Make sure whether you go to the dealer or the local guy that no work is to be done without your approval. Lookfor a place on the work order for you to indicate this. There may be a small charge for checking out your problem.
If you have no way of checking this out yourself I don't see another solution.
edmund
06-28-2008 11:21 AM
pepsipackin
11-14-2007 11:49 PM
dhsman
10-19-2007 10:32 PM
rbradney
10-14-2007 06:20 PM
JP500
09-03-2007 07:13 PM
Quick Reply: Diagnostic Codes... What Do These REALLY Mean???
