2001 Deville Crossover mishap
Old 07-22-2016, 06:53 PM
John Lentini's Avatar
Cool 2001 Deville Crossover mishap
While attempting to block the upper radiator hose housing, on the crossover, I placed a mouse ball in the opening and it proceeded to roll away out of sight. I took off the thermostat and water pump , but, no sign of the ball. The ball is 1/2" diameter steel covered in rubber. It does not float. Does anyone know where it could have ended up???
Old 07-23-2016, 06:01 PM
I don't understand what you were doing, If your lucky you might find it if you remove crossover, most likely in cylinder head.
Old 07-23-2016, 07:15 PM
Thank-you Slowroll. I was attempting to pressure and smoke test the block only. I had already discovered that the radiator leaked intermittently and the neck of the coolant reservoir relieved pressure before the 18# cap. After web surfing I became convinced that the head gasket was bad although no white smoke and the car runs great all winter. I believe that the ball made it to the head as you suggest. If I leave it there will it possibly end up at the thermostat? I appreciate your reply. Thank-you
Old 07-23-2016, 11:46 PM
Slowroll, You had correct location for the location of the steel ball. I snaked it out with a super magnet wired through 1/4" rubber house extended to the head. I snagged the ball on the first attempt. Thanks again
2003DeVille
11-24-2015 02:03 PM
smoky614
09-18-2015 12:50 PM
Clockworkmiss
05-22-2014 08:51 PM
montrose2914
04-13-2012 05:32 AM
Lithorian
03-29-2008 05:42 PM
Quick Reply: 2001 Deville Crossover mishap
