Parts........ FWD
Parts........ FWD
*Exmaple 4 speed
Transmission Case
1st inputdrive gear (1)
2nd inputdrive gear (2)
3rd inputdrive gear (3)
4th input drive gear (4)
Input cluster assembly (1,2,3,4)
1st output speed gear (5)
2nd output speed gear (6)
3rd output speed gear (7)
4th output speed gear (8)
Drive Pinion gear& output cluster assembly (5,6,7,8)
Reverse Idler gear (straight cut)
1st & 2nd synchronizer
3rd & 4th synchronizer
Thrust bearings
Ring gear
Carrier
Pinion gears
Pinion shaft
Carrier bearings
Transmission Case
Thrust bearings
Ring gear
Carrier
Pinion gears
Pinion shaft
Carrier bearings
RE: Parts........ FWD
Hey Big 5: Go to www.usapartssupply.com you will find a lot of good stuff. You can call them to check on the trans. parts and gaskets sets. Good luck.
I have tons of parts catalogs, I was just posting these for those who dont know much internally of a transmission. Besides I saw that there was nothing in the manual transmission forums for I decided to atleast have these for people who are wanting to know the information. Thanks though Brougham1
pcbang
07-06-2006 03:35 AM
