Home Projects Got something special planned for around the home? This is your place.
Balancer Bolt 96 Seville
Old 04-05-2017, 05:01 PM
Joed2112's Avatar
Talking Balancer Bolt 96 Seville
Do I need too Change Balancer-bolt when pulling balancer off and replacing Balancer? I know the spec for tightening 37ftp and 120 deg. Any help will be appreciated. Thanks
Old 04-05-2017, 08:29 PM
You shouldn't. Oil pump is not keyed to crank it is driven by the clamping force of balancer bolt.
Old 04-05-2017, 10:27 PM
Joed2112's Avatar
Ok so replace bolt from GM dealer. Thanks greatly appreciated
Old 04-06-2017, 11:56 AM
So Long's Avatar
Old 04-07-2017, 07:03 PM
Joed2112's Avatar
Ok got the bolt, put it in, but what a tough pull to get 120 degrees on the crank. no leaks, so got the job done! Thank for all the help guys, (from 96 Deville Harmonic Balancer replacement) works for Seville too. Thanks
Old 04-09-2017, 11:11 PM
Joed2112's Avatar
Thanks Slowroll for pointing out; you always replace a stretch bolt after its been tightened once. I am looking forward to reading more post from you, in the future. Thanks again
1olpharte
04-05-2017 03:31 PM
1putt
01-30-2008 07:25 PM
Virginia John
11-23-2007 06:10 PM
bigredtodd
06-27-2007 05:08 PM
Quick Reply: Balancer Bolt 96 Seville
