what does engine diagnotic code po174 and po171 truly means? - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 05-28-2010, 06:19 PM
Exclamation what does engine diagnotic code po174 and po171 truly means?
i have a cadillac deville 2001 standard edition that i've been having for the last 8 years and i have kept in good condition and taken care of it maintenance,mechanical stuff ! but recently i have been getting this loud weezing noise that comes on when the engine is cold and i just turn the car on ! this noise comes from the left driver side of the car under the left headlight area and air filter area! then just the other day,my service engine soon light came on so i had an engine diagnostic done at a professional auto mechanic spot "PEP BOYS" and they pulled these following codes : PO171 AND PO174 ..these codes were showing numerously ! stating that the car was running too lean and the pep boys technician also stated that fuel system too lean bank 1 and bank 2
he said that the car either is getting too much oxygen or not enough fuel ! but yet there were no oxygen sensors codes showing !
i also recently had done these following maintenance services on the car :
complete engine flush with oil change semi-synthetic and filter, power steering flush, brake flush, radiator cooling system flush, fuel injection system cleaning service
while doing the engine diagnostic,the technician found where the weezing noise was coming from which was the secondary air injection auxiliary pump which was containing water inside of it ! so at this point, i would like to know do i need to change that pump and if by doing so would it take care of the service engine light! also i keep finding no parts named secondary air auxiliary pump on the internet when i am doing my searches for pricing and info ??
thank you very much for any help provided !
Old 05-28-2010, 07:29 PM
Default P0171 and P0174
The first thing to check with those codes is your plenum duct. Check it for a tear in the bottom by running the car at low idle and spray a little starting fluid under the bottom. The plenum duct is a short rubber connector between the throttle body and the intake manifold. Observe the idle while you spray a short spurt of starting fluid under it and if the idle raises, then the plenum duct must be replaced. All plenum ducts will develop a leak at this location due to the design of the vehicle. You would be lucky to get 100K miles before it goes.
Other causes include vacuum leaks at the air incuction system, intake manifold, and injector o-rings; leaks at the crankcase ventilation system, and missing, loose, or leaking exhaust components. The secondary air pump is an exhaust component. It is about a $150 part and includes numbers 12 - 17 in the attached picture.
what does engine diagnotic code po174 and po171 truly means?-air-pump-part-2-6k0303101.jpg
Old 05-28-2010, 11:44 PM
when you say run the car at low idle, can you explain how is that done ?
do i just turn the car on and let it run, is that considered low idle if nothing else is applied to the car?
also as far as spraying the starting fluid, where do i exactly spray it? at the connection of the throttle body and the intake manifold?
also i'm having a hard time finding air auxiliary pump product on any sites because for some reason it says that it doesn't exist! is air auxiliary pump another name for air injection pump or just simple air pump ?
i would greatly appreciate for any input and help provided ?
thank you !
Old 05-29-2010, 12:24 PM
Yes, wait for the car to warm up and the idle will fall to low idle.
Yes spray all around the connection because in addition to a hole or tear developing, the rubber ridge that contacts the aluminum at the water crossover can wear away causing a leak between the plenum and the water crossover. The throttle body mounts to the water crossover which is less than a couple of inches thick at that point. If this is your problem, you must replace the intake manifold gasket set when changing the plenum and it is a good idea to replace the throttle body gasket while you are there.
Secondary air injection pump.
Start at http://www.gmpartsgiant.com/genuine/gm-parts.html and use their search by VIN feature.
Go to section: Fuel System, Exhaust, Carburetion, Emissions
Go to component: A.I.R. Pump and Related Parts
Look for: Pump Kit, Secondary Air Injn
Where does the Duralast Engine Management and Ignition Sensor go on this car? JasonCTS Cadillac CTS 0 01-01-2015 01:41 PM
evap code and maf code joshholman Cadillac STS 0 03-13-2010 06:25 PM
Where is the turn signal flasher and what does it look like 9treseville General Tech 1 12-06-2008 10:35 AM
can you walk on water ? HOW DOES A HYDROGEN ENGINE WORK? stomper Off Topic 1 07-07-2008 09:56 AM
Under Engine Codes, what does "ALL ID" mean? JP500 General Tech 2 09-03-2007 07:13 PM
Tags
2001, bank, caddilac, cadillac, code, cts, deville, diagnostics, duct, engine, lean, plenum, po171, po174, system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
