89 Allante no start
89 Allante no start
Well I turn the key, and nothing first couple times you may hear a faint metallic click but then it wont do it anymore. No security lights or anything when I try to start. If I jump the solonoid it'll turn right over and work from the key sometimes after that. What do ya'll think, could it be the starter?
your battery needs to be retired ...
It got a new one in march, and still does this with a jump box attached. I should be specific you get electrical power otherwise, byt lights I mean like a corvette would have a security light come on if it was a Vats problem.
Well I turn the key, and nothing first couple times you may hear a faint metallic click but then it wont do it anymore. No security lights or anything when I try to start. If I jump the solenoid it'll turn right over and work from the key sometimes after that. What do ya'll think, could it be the starter?
use the elimination process
nothing wrong with starter
nothing wrong with battery
so what's between battery and starter? VATS and theft deterrent.
start with the most likely and cheapest .. try another key and hope its the pellet that lost it.
then the key lock cylinder
after that, the wiring between the key and the module.
after that, theft deterrent system
04-25-2023 05:44 PM
Cadillac Allante FAQ
05-27-2013 12:44 AM
Dennisoates
Cadillac Allante 1987 to 1992 Phase I & II
05-25-2012 10:13 AM
