Sponsored by:
Sponsored by:
trouble code help
Old 03-12-2007, 12:25 AM
brougham1's Avatar
Default trouble code help
Have recently pulled trouble code 30 and 38 on my 1981 Fleetwood Brougham and can't find a thing in my repair manual that pertains to these numbers. Any help would be appreciated, I have the 6.0l engine and it's RWD.
Old 03-12-2007, 02:21 AM
Katzmans Caddy's Avatar
Default RE: trouble code help
Hope this table helps:
1980's Diagnostic CodesThe following codes are programmed
into the ECM
Code
Circuit Affected
00 (E00)
No PCM systems faults
12 (E12)
No TACH Signal
13 (E13)
O2 Sensor Not Ready
14 (E14)
Shorted Coolant Sensor
15 (E15)
Open Coolant Sensor
16 (E16)
Generator Voltage Out Of Range
17 (E17)
Crank Signal Circuit High
18 (E18)
Open Crank Signal Circuit
19 (E19)
Fuel Pump Circuit High
20 (E20)
Open Fuel Pump Circuit
21 (E21)
Shorted Throttle Position Sensor Circuit (DFI)
Wide Open Throttle (WOT) Position Sensor Circuit (all others)
22 (E22)
Open Throttle Position Sensor Circuit
23 (E23)
EST/Bypass Circuit Shorted or Open (DFI)
Mixture Control (M/C) Solenoid Open (Carbureted)
MAT Sensor Circuit - Low Temp (TBI/all others)
24 (E24)
Vehicle Speed Sensor (VSS) Failure
25 (E25)
Modulated Displacement Failure (v8-6-4)
EST/Bypass Circuit Shorted or Open (HT4100)
MAT Sensor Circuit - High Temp (TBI/all others)
26 (E26)
Shorted Throttle Switch Circuit
27 (E27)
Open Throttle Switch Circuit
28 (E28)
Open Fourth Gear Circuit
29 (E29)
Shorted Fourth Gear Circuit
30 (E30)
Idle Speed Control Circuit
31 (E31)
Shorted MAP Sensor Circuit (DFI)
Canister Purge Problem (all others)
32 (E32)
Open MAP Sensor Circuit (DFI/TBI)
BARO Sensor Circuit Problem (Carbureted)
33 (E33)
MAP/BARO Sensor Correlation (DFI)
Shorted MAP Sensor Circuit (all others)
34 (E34)
Vacuum Sensor/MAP Hose (DFI)
Open MAP Sensor Circuit (all others)
35 (E35)
Shorted BARO Sensor Circuit (DFI)
Idle Speed Control Circuit Shorted (all others)
36 (E36)
Open BARO Sensor Circuit
37 (E37)
Shorted MAT Sensor Circuit
38 (E38)
Open MAT Sensor Circuit
39 (E39)
TCC Engagement Problem
41 (E41)
Electronic Spark Timing (EST) Problem
42 (E42)
Electronic Spark Timing (EST) Circuit Open
43 (E43)
Electronic Spark Control (ESC) Problem
44 (E44)
O2 Sensor Lean
45 (E45)
O2 Sensor Rich
51 (E51)
PROM Insertion Fault
52 (E52)
ECM Memory Reset Indicator
53 (E53)
Distributor Signal Interrupt (HT4100)
ECM Unit Fault (V6 Models)
EGR Valve Vacuum Problem (all others)
54 (E54)
Mixture Control (M/C) Solenoid Shorted
55 (E55)
ECM/Oxygen Sensor Fault
60 (E60)
Drive (ADL) Switch Circuit
61 (E61)
Set and Resume Switch Circuit
62 (E62)
Car Speed Exceeds Maximum Limit
63 (E63)
Car and Set Speed Tolerance Exceeded
64 (E64)
Car Acceleration Exceeds Maximum Limit
65 (E65)
Coolant Temperature Exceeds Maximum Limit
66 (E66)
Engine RPM Exceeds Maximum Limit
67 (E67)
Shorted Set Or Resume Circuit
70
System Ready - Switch Tests
71
Brake Light Switch
72
ISC Throttle Switch
73
Drive (ADL) Switch
74
Back-Up Lamp Switch
75
Cruise On/Off Circuit
76
Set/Coast Circuit
77
Resume/Acceleration Circuit
78
Instant/Average MPG Button
79
Reset MPG Button
80
A/C Clutch Circuit
88
Display Check (-.1.8.8)
90
System Ready To Display Engine Data
95
System Ready for Acuator Cycling
96
Actuator Cycling
97
MD Cylinder Solenoid Cycling
00
All Diagnostic Complete
into the BCM
Code
Circuit Affected
F00
No BCM System Faults
F10
Outside Air Temperature Circuit Problem
F11
A/C High Side Temperature Circuit Problem
F12
A/C Low Side Temperature Circuit Problem
F13
In-Car Temperature Circuit Problem
F19
Blower motor failure
F32
BCM to ECM date transfer problem
F40
Air Mix Door Problem
F41
Cooling Fans Problem
F46
Low A/C Refrigerant Condition Warning (1/2 charge)
F47
Very Low A/C Refrigerant Condition Warning (1/4 charge)
F48
Very Low A/C Refrigerant Pressure Condition
F49
A/C High Side Temperature Too High (temperature exceeds 200°F)
F50
Coolant Temperature Too High (exceeds 259°F)
Old 03-12-2007, 04:14 AM
what else is happening?
are you getting an rpm surge or other symptoms?
ORIGINAL: brougham1
Old 03-12-2007, 03:02 PM
brougham1's Avatar
Thanks for the codes Katzman I did suspect the position sensor as I have adjusted it before and not sure if it is just right yet. In response to Stealth, the only thing that seems to be affected is the idle, it seems too low when cold and a bit too high when the engine is hot. The service engine light is sometimes on and sometimes off. Map Open Sensor Circuit is that a replacement issue???
Old 03-12-2007, 03:15 PM
I believe that MAT is Manifold Air Temperature sensor. Now you've got the6.0 lwhich I have not seen in a long time but on newer cars this is a little probe in the air duct leading to cleaner assembly. Not sure where this would be on your torque monster but it must be in either the snorkle or assembly. It is probably a grey or black connector going into the assembly.
Old 03-12-2007, 07:42 PM
brougham1's Avatar
Hey Katzman: Found the Mat and Map sensors, they are both attached together to a metal bracket right near the ECM which is behind the glove box. They both look identical but the numbers are one off each other 832 and 833. Should there be a vac. line on the Mat sensor, the vac port is bare and open where as the Map sensor has the vac. line attached.
Old 03-12-2007, 07:55 PM
brougham1's Avatar
Back up the Caddy: The Baro sensor is near the Map sensor and this is the one that has the bare vac. port so sorry for the confusion. I will check the Mat. sensor location and see where it's at . Thanks for the help.
Old 03-12-2007, 11:13 PM
I think on the air cleaner, I am envisioning a wire harness going to a grey connector.
NOGUTSNOGLORY
08-29-2014 10:43 AM
CAdMan80
11-28-2008 11:06 PM
Capriceman76
11-30-2007 10:43 PM
prowl583
09-08-2007 08:47 AM
toms46
04-04-2007 12:41 PM
Quick Reply: trouble code help
