Stabilitrak Issues
Stabilitrak Issues
Hi all, I'm a new member, I am having problems with my 2007 Esclalde. After blowing a rear tire, I had used the spare to get to the tire shop. The tire shop was able to provide me with an exact match to the rest of the tires with equal tread wear.
An hour after leaving the tire shop the DIC was reading: Stabilitrac System Disabled, Service Stabilitrac System, Park Assist Disable. The traction control light and the check engine lights appeared on the display. The truck was not shifting gears. I pulled over, turned the truck off and restarted. The lights were still on, the DIC was still wacky but the truck shifted and drove normally. A short while later the traction control light turned off. Check engine light remains on.
Any help with these issues would be apreciated. Thank you in advance.
Michelle, Cadillac Customer Service
Stabilitrak Issues
Oddly enough, all the lights on my panel have gone out, the truck seems to be running and driving fine. Should I still be worried? Do I need to get it to the dealer?
Hopefully not, thanks for your input.
I would take the vehicle into the dealership to see if there are any codes that they can pull for when the lights were on. If might provide you with some peace of mind.
On the other hand if there are not codes pulled, you can make sure the dealership do***ents your concerns which can prove to be helpful if you have this happen in the future.
Des324
10-07-2018 08:45 PM
Des324
10-07-2018 08:35 PM
