Sponsored by:
Sponsored by:
SEVERAL ENGINE CODES 2000 deville ANY SUGGESTIONS? PLEASE HELP
Old 07-22-2007, 11:32 PM
jakemoore83's Avatar
Default SEVERAL ENGINE CODES 2000 deville ANY SUGGESTIONS? PLEASE HELP
I have 4 engine codes coming
Old 07-23-2007, 04:35 AM
FLCaddytech's Avatar
Default RE: SEVERAL ENGINE CODES HOW ANY SUGGESTIONS? PLEASE HELP
Year ?
Make ?
Model?
Engine?
The codes you listed point to a Northstar engine.
That is the only Caddy i know to have 2 crank sensors.
But i would rather not guess at your problem.
Old 07-23-2007, 11:04 AM
Twocodes you listed could be set by problems with the crank sensors.
Your year and model had several updates on the crank sensors.
The latest ones are black (bottom) and grey(top) in color.
If your crank sensors are the old yellow and tan i would get the new ones on there before going further.
Old 07-23-2007, 11:59 AM
If you locate the oil filter then look up and right(towards the driver side)on the engine block.
Directly behind the front motor mount bracket.
andrew_laddick
12-04-2009 03:13 PM
mrcrx28
03-13-2008 05:32 PM
dhson22s
10-07-2007 09:22 AM
Vehicular Projects
05-18-2007 08:20 AM
Quick Reply: SEVERAL ENGINE CODES 2000 deville ANY SUGGESTIONS? PLEASE HELP
