Service Engine Soon Light on 2000 DeVille
My cam sensor, cardone,andcrank position sensor codesare going off...i recenly had my tie rods replaced and all of these codes started popping up on the way home from the shop...im wondering if they moved something around the wrong way or bumped one of these sensors to cause my sensors to go crazy. Could they have possibly moved a ground wire and caused it to go off or maybe even bump one of the sensors on the front of the engine? Any ideas guys?? I foundout what codes are popping upby taking my car to Auto Zone and letting them do a free diagnostics on it...thanx for the help!
RE: Service Engine Soon Light on 2000 DeVille
It is a possibility, they could have bumped a sensor but the only way they could have done that is if they stuck his/her arm in the engine compartment while doing the inner tie-rods. Also the outter tie-rod is not even close to the area when doing this R&R though. There could be some loose connections but it could also be the sensors sensing something or just time for R&R on those also unless you are able to find something else wrong with it. Those Autozone code readers are just generic tools, they won't pin point the problem like a actual factory GM, Ford or Chrysler etcdiagnostic computer will.
FriscoSLS
03-23-2012 02:19 PM
