Sponsored by:
Sponsored by:
ok i need help
Old 12-06-2007, 08:10 PM
2000 caddy deville's Avatar
Default ok i need help
ok i have a 2000 deville that keeps throwing up p0300 i replaced both the coil pcaks but it still throws the same p0300 code one minute it will run fine but then it just starts skipping what else could cause this code?
Old 12-21-2007, 09:31 PM
Default RE: ok i need help
connectors from coil to spark plug being carbon tracked, injectors, contaminated fuel, ground, ecm. You have generic misfire code, dealer scanner (Tech2) may be able to isolate which cylinder is misfiring.
Gregg Reed
04-13-2014 09:09 PM
cadillactt
03-12-2008 01:31 AM
kmac171
02-20-2008 10:36 PM
nizmosis
09-30-2005 06:20 PM
redbirdT/Aws6
12-22-2004 01:31 PM
Quick Reply: ok i need help
