Sponsored by:
Sponsored by:
Need some advice on 4.6 northstar surging please
Old 04-09-2007, 11:33 AM
gwmcintire's Avatar
Default Need some advice on 4.6 northstar surging please
Hello, new member here. I have a 96 Deville with the northstar engine and having surging problems after the engine warms up. Dealership could not locate what was causing the problem and a local repair shop thought replacing the intake gaskets would fix it because they suspected a leak.After changing the intake gasket thiswas also unsuccessful. I would welcome any ideas for what might be causing this surging, thanks.
Old 04-09-2007, 02:02 PM
Default RE: Need some advice on 4.6 northstar surging please
Have you tried pulling the codes? If not, please do so and tell us about'em.
Old 04-10-2007, 07:15 PM
FLCaddytech's Avatar
I have seen more than one 96 year model with idle problems caused by a faulty PCM.
Unfortunately all other possibilities need to be eliminated before condemning the engine computer.
Old 04-12-2007, 12:38 PM
gwmcintire's Avatar
Thanks for the replies so far. I should clarify that the surging is while driving and not at idle. I assume the dealer already pulled the codes when it was in for this problem if there were any. I did not ask for them or what they were, regardless they were unable to locate the problem.
utahpaul
07-09-2010 09:45 PM
caddigoes
06-06-2009 09:08 PM
real_ivan_ivanov
05-21-2009 09:13 AM
Bigwilly
08-08-2006 05:03 AM
TOMMYDeVILLE
10-07-2005 08:04 PM
Quick Reply: Need some advice on 4.6 northstar surging please
