Need Help Information Center, Air Heater not Worknig
Hi, the information center has quit working in my 1992 De Ville. I hope someone can help. The following instruments are effected.
Fuel Data Center, Fuel in tank. In addition the Electric Climate Control is not working that controls outside temp display, warmer/colder, defrosters, and air conditioner.
When I first start the engine, all the sections in both the FDC & ECC panels light up for just a second and then go out. But after this nothing.... and nothing works, no heat, no air, no display..
Note all of this stopped at the same time and one would think it's a fuse. So I checked all the fuses under the dash and all of the maxi fuses and they all "look good"
is there any other fuse or relay I should check or could someone direct me to where I should look next?
Thanks for your help,
Ken
Ken
Paulforhelp
07-06-2011 02:33 PM
Paulforhelp
07-06-2011 09:05 AM
