Maybe I need a good tune up? 1997 Cadillac Seville SLS
Gents,
When we changed the power steering pump, I noticed the pcv boot was cracked at both ends and had been stitched up with electrical tape. No worries, got the valve, grommet and hose ordered at local Caddy Dealrship to arrive tomorrow.
It has been running a tad rough and I pretty much figured that may be the case. Well today it shuts off and fires back up. My engine temp runs between 196-199 running and 201-204 atshort to medium idle times.
1997 Seville SLS 171K
Got her home and checked codes (thanks to this site) and I got the following.
1. P0101-Mass Air Flow (MAF) Sensor Performance.
2. P0171-0174 Lean bank.
3. P1599 - Engine Stall or Near Stall Detected.
4. P1611 - Loss of CVRTD Serial Data.
5. B1552 - Keep Alive Memory (KAM) Error
In short, I'm thinking maybe my EGR might need cleaned and inspect theplugs and wires.
Just asking for a little insight if there is something else I should look at. I'm mainly a Mustang guy and although I have both manuals, I'm not quite familiaryet with the Northstar.
Just asking for a little insight and apologizing for the short novel.
Mod edit
Title
Mod edit
Title
RE: Maybe I need a good tune up?
Vacuum leak could cause P0171, P0174, & P0101. After you fix PVC hose clear codes and see if they come back.
P1611 and P1552 check condition of battery, battery cables, and ground connections.
P1599 - related to lean/ maf concern.
Good call Slowroll. I also found a small plastic line leading from the back end of the manifold to a "t" and then a clip on the firewall was sliced open. I had a few line connectors laying around and got that fixed.
I thought ofrunning seafoam in the intake. Any specific line I should use?
ORIGINAL: Hardrive
Gents,
Gents,
What you provided is what we need from everyone that wants help.
EVERYONE, follow his lead ..
thanks
Please help me 97 sls
Changed a hose , while doing so i arcked the battery. Afterward , would not start . Battery read fine . Jumped it off . 2 seconds . Later that day while driving ,. Lost power . Not all power . Checked all fuses batt. Cables . Still will not turn over . Has some power . Certian things. Please try to help me.. Thank you
