Re: blower motor & power windows not working
I have a 67 Eldorado & I have just installed the radiator with the new heater hose port & luckily the heater core is OK. The water valve leaked a little so I will try to repair or replace. I am having trouble with the blower motor though, it was working before & does work when I put power to it. I recently removed the radio & the door panels so I could rust proof the inside with POR 15 & clean & grease the window mechanisms. I am wondering if I could have shorted something out, the windows also stopped working unless I push the lock switch to emergency & it then works. All fuses are OK. Thanks for your help on the radiator. Any advice would be appreciated.
Dan
Dan
