Sponsored by:
Sponsored by:
How HOT is HOT for a northstar engine. When do you suspect blown head gaskets
Old 11-15-2007, 04:27 PM
bighank's Avatar
Default How HOT is HOT for a northstar engine. When do you suspect blown head gaskets
What is considered HOT in terms of temperature to suggest a blown head gasket?
Last week drove a 97 Deville with AC on and at highway speeds and also start stop and it showed a temp of 212 on the display. The outside air was only about 51 so I have no idea what the temp would be in 90 or 100 degree air which we generally have in the summer in MD.
My C5 Corvette with the LS1 engine ran at a max of 189 degrees under the same conditions. Was the Deville exhibiting overheating in this cold air environment.
What do you consider NORMAL for the temp in this weather?
BIGHANK
Old 11-15-2007, 05:01 PM
Default RE: How HOT is HOT for a northstar engine. When do you suspect blown head gaskets
Prolonged operating temp over 235 on open highway. Normally should stay under 220 even on hot days. I would suggest to flush cooling system if there is any doubt of its condition. In town if cooling fans can't control engine temp
Old 11-18-2007, 07:50 PM
driving around, that sucker can go as high as 234... but on the highway, it should stay closer to 200 210.... I have noticwd by reading threads that all caddy's run different temps... that is just ahigh but still a good range..
Alex
overmyhead
Aluminum Block V8s
22
09-18-2023 07:27 AM
Kelso
07-13-2011 03:55 AM
culltwojc
10-17-2008 10:53 PM
VIN9
Aluminum Block V8s
09-19-2007 09:18 PM
MattyNJ
12-24-2006 04:31 AM
Quick Reply: How HOT is HOT for a northstar engine. When do you suspect blown head gaskets
