help with oil change 1973 Eldorado - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 04-20-2017, 09:56 AM
Default help with oil change 1973 Eldorado
I've got a 1973 Eldorado convertible I'd like to do an oil change on. After getting under the car, it looks like there are two drain plugs. I'm not sure if they are both for engine oil or one if for the transmission. Did this car even have a transmission drain plug? I don't want to pull off the wring drain plug.
Old 04-20-2017, 12:19 PM
There are 2 drain plugs because oil pump is a front engine, and output shaft runs under oil pan. There shouldn't be much oil coming from front sump. Most of the oil will come from rear sump.
Old 04-20-2017, 02:30 PM
THank you for the info! I just got done changing the oil and you were right about the front not having too much. Piece of cake and now comfortable doing my own in the future.
GM Oil Life Monitor - 99 Eldorado "Change Oil" comes on a few days after reset chester_007 General Tech 6 03-07-2011 05:44 AM
1973 Cadillac ElDorado Help with dropping fuel tank etohboy Vintage & Classic Cadillacs 1 09-28-2009 05:25 PM
472 no oil pressure after oil change? hl8a Big Block V8s 1 09-08-2008 06:18 PM
Oil Change & Filter Change SoulRebel Cadillac V Series 3 11-09-2007 04:34 AM
Help with oil change 206lac206 Cadillac Escalade 4 09-10-2007 08:17 AM
Tags
1973, eldorado, oil
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
