Sponsored by:
Sponsored by:
Fuel pressure regulator
Old 06-27-2008, 09:57 PM
97Devile's Avatar
Default Fuel pressure regulator
How do you replace the fuel pressure regulator on a 1997 Cadilac Devile? Thank you in Advance.
Old 07-04-2008, 06:57 PM
97Devile's Avatar
Default RE: Fuel pressure regulator
Well I have a friend who works for GM and he gave me the replacement procedure for the fuel pressure regulator. One remove the gas cap, second remove the fuel pump fuse, third start the car let it run until it stops, keep starting it until it will not start anymore. Then put a cup over ther pressure release rail to catch the gas and press the release valve until the all the pressure is out.
Once this is done use a needle nose plier or pliers to remove the clamp over the fuel pressure regulator. Grab and pull the fuel pressure regulator out of the value area. Put the new regulator in and clamp it down.Put the fuel pump fuse and gas cap back in place. Start the car.
That is it, guess what that was my starting and stalling and backfire problem. Thanks to a GM worker.
Old 09-12-2008, 04:15 PM
also to check for bad fuel regulater pull of va*** hose and check for fuel... had same problem with starting and idle but i also had a blown seal in my intake manifold also i had to replace that
strabo40
08-08-2012 02:55 PM
wsh777
12-02-2011 09:08 AM
michaeldkania
05-24-2007 08:36 AM
latinowarrior
08-19-2006 08:23 PM
transtechterry
02-24-2006 12:37 AM
Quick Reply: Fuel pressure regulator
