Faulty Ground Wire
Old 07-30-2008, 10:56 AM
devillerunfoever's Avatar
Default Faulty Ground Wire
'94 Cadillac Deville 4.9L
Error codes:
P047
P052
P091
I052
... so I took it to the dealership to find the problem. The dealership said I have a ground wire problem and may take several hours to find. Has anyone experienced this problem? Is there a specific place to look for loose, corroded or damaged ground wires? Does the negative battery cable need to be replaced, etc?
Thanks!
Old 09-01-2008, 10:02 PM
Default RE: Faulty Ground Wire
ORIGINAL: devillerunfoever
Error codes:
P047
P052
P091
I052
Thanks!
there are several in every car.
the most typical issues are with the battery cables and the engine block grounds but it could be any ..
you need a FSM for your car to chase them all. spend the $40 it will be worth it.
chopperhopper
Cadillac EXT
136
01-26-2017 12:40 PM
red97sts
05-22-2013 12:34 AM
abyrd01
Automatic Transmissions
06-26-2012 10:41 PM
Cord
06-24-2012 09:17 PM
JP500
08-14-2007 09:36 PM
Quick Reply: Faulty Ground Wire
