fans will not work
fans will not work
hello my name is Tracey i am new to the forum.... i have a 1994 eldorado and recently all of my fans have stopped working.... heat, A/C and the defrosters all will not work... we have checked the fuses and they are all fine....
does anyone have any idea why they wont work?
thanks,
Tracey
RE: fans will not work
Probably the fan power module. Expensive guess. they cost roughly $100.00 thru www.gmpartsdirect.com. Located at firewall underhood.
Dont get side tracked. A pressure switch has nothing to do with fan operation, just air temperature. Good point tho to run a wire from the fan to the battery to rule out the fan itself, but my experience says a fan motor fails slowly over time and gets noisy or smells like burning wire just before it quits altogether.
ORIGINAL: carnut
arent the same units used on the Allante and for that matter on most all Cadillacs of the era?
hint .. salvage yards .....
very easy to R&R
shelley
11-12-2012 06:39 PM
