Engine misfire? - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 04-17-2009, 10:16 AM
Default Engine misfire?
I am new to the forum but I have read and used some of the info. posted. My car which is a 1991 Cadillac Devile 4.9 V8. Last month the car started to vibrate roughly. It had a barely noticeable vibrateion maybe (miss) since I had the car now 3 months.
Error code E30 E91, E98 there were others before I reset the codes now these seem to be left over.
What was done: Changed all spark plugs and wires, changed PCV, fuel filter, air filter. Note: some of the spark plugs had carbon and tech person said maybe too rich fuel (gas) or possible coolant leak not confirmed.
Problem: I am trying to fix the (missfire, inconsistent idle)
Question what would be the most likely cause of this problem, I was thinking the EGR valve because when inspected I saw a crack in the base of the part that attaches to the engine. On the forum coil(s) were mentioned as a probable cause please advise steps.
Phut7
Old 04-17-2009, 10:24 AM
Phut7
most likely ...
coils, plugs, plug wires, throttle intake ...
"Error code E30 E91, E98 there were others before I reset the codes now these seem to be left over. " what do you mean by "left over" ?
Old 04-17-2009, 10:42 AM
Thank you for reading post. The coed that I had before I did anything was E30, E55, E71,E98,E99
F11, F40, F48 (i still do have these F codes which I believe are related to air condit)
To answer question this is what I have presently E30,91,98, F11, F40, F48
Last edited by phut7; 04-17-2009 at 11:00 AM. Reason: left out some code information
Old 04-17-2009, 11:18 AM
have you had the tps cleaned lately? also, advise stomper gave...plugs/wires is where id start...
Old 04-17-2009, 11:27 AM
TPS- I think this means throttel position sensor. Sorry I am still learning. Please let me knwo where it is located and how to clean.
Old 04-17-2009, 11:38 AM
tps is at the intake and works the throttle plate.... youll need to take apart. sorry the tps is electrical, and you cant clean it, but you'll need to spray carb cleaner into the throttle plate to clean it ..... spray, rev engine, spray again, rev and spray again. but i would change plugs and wires also. .........big time
Old 04-17-2009, 11:57 AM
I will try clean up the throttle plate. I mentioned in my original post that I replaced all of the wires and spark plugs about 2 weeks ago. the car ran a little better but the misfire was still happening .
Old 04-17-2009, 01:01 PM
yea... i read it and .....well sorry..... brain fart!!... yea clean that plate real good, lets see what happens. also i think at this point i would read in the faq section, WOT... and do that. give'r a good runnin that way, and a good clean..
let the forum know how you make out
Old 04-20-2009, 12:58 PM
I played mechanic this weekend and took off the TPS to view and "clean" the throttle body fo rthe second time even though it was pretty clean already. Note: when I tried to unscrew TPS both screws broke off. I drilled out one of the remaining screws and palced another screw in its palce.
I have already changed the coil on top of the distributor cap (junkyard to see if changed), rotor wires, spark plugs, fuel filter, air filter, cleaned throttle plate.
Yesterday I took for a drive, still the miss was there but I noticed that the power increased and seemed to accelerate quicker. today I drove it to work and it seems a little better but miss is still there. Any advice?
Old 04-21-2009, 07:18 AM
Default After EGR,plug,wire,coil,distr,rotor,--
Update- After changing the EGR valve that had a crack in the right base where the screw is located with a (cleaned) EGR valve from junkyard the car improved about 40% (more power, less chugging when up an a hill or accellerating). However I still have what seems to be a miss- ERROR code E30, 52, E91, E98, please advise.
PCM P0300 - Engine Misfire Detected bsstyle2011 Cadillac Seville 1 04-14-2011 12:48 PM
1991 deville engine misfire savvia General Tech 6 01-29-2009 12:03 AM
2001 DTS Engine misfire detected... why? summitgirl Cadillac Deville 26 06-30-2008 08:40 PM
P0304 - Cylinder 4 Misfire Detected spencerhcollins General Tech 4 03-09-2008 11:45 AM
AC Delco spark plug wires, engine misfire ... Stealth General Tech 2 06-05-2007 07:10 PM
Tags
49, cadillac, coil, escalade, idle, injector, misfire, misfires, miss, owners, plug, power loss, seville, spark, speed
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
