Sponsored by:
Sponsored by:
Dtc u1000
Old 05-13-2011, 07:39 PM
optimummaximum's Avatar
Default Dtc u1000
I have a 2003 Deville. Recently the Engine light has been illuminated. Running through the codes I am noting U1000 Current.
Also, while running through the codes I am noting "No MSM data"
Please help.
I know it is a communications issue. Are these two items related?
Old 05-14-2011, 11:54 AM
gmtechs's Avatar
means no communication with that module
Old 05-28-2011, 04:41 PM
Default msm module
Where is the MSM module.
How do I troubleshoot a comm issue. Should I just replace the module.
Old 05-29-2011, 07:27 AM
gmtechs's Avatar
i believe that is the memory seat module should be under the driver seat
broken wire or unpluged
Old 06-21-2011, 03:00 PM
burntyres's Avatar
Default IPC U1000 code
My 2003 SLS runs great (66k miles) but it failed the Indiana Emissions testing due to lack of communication and not real emissions. I reset all the codes and the only code I get is IPC 1000 Current. Previously I had a crankshaft sensor velocity "B" (I think it was a 306) that had the check engine lite on but they both cleared on the reset. I get the IPC 1000 whether the engine is running or not. Where is the IPC? and what should I check for. Thanks
ItsJustLia
11-04-2012 07:09 PM
bighank
11-22-2007 09:14 AM
bighank
11-13-2007 06:08 PM
Squeeky
02-10-2007 04:25 PM
JJ91284
06-23-2006 09:26 PM
Quick Reply: Dtc u1000
