DTC-Codes Meaning
DTC-Codes Meaning
Body control module----this is for most vehicles
Diagnostic Trouble Code (DTC) List - Vehicle
DTC Descriptor
DTC B0001 PCM Discrete Input Speed Signal Error
DTC B0012, B0013, B0014, B0016, B0017, or B0018 Right Front/Passenger Frontal Deployment Loop Circuit
DTC B0022, B0024, B0026, B0042, B0043, or B0044 Left Front/Driver Frontal Deployment Loop Circuit
DTC B0028, B0029, or B0030 Right Front/Driver Side Deployment Loop Circuit
DTC B0040, B0041, or B0045 Left Front/Driver Side Deployment Loop Circuit
DTC B0051 Deployment Commanded
DTC B0053 Deployment Commanded with Loop Malfunctions Present
DTC B0057, B0058, or B0059 Left Front/Driver Frontal Deployment Loop (Stage 2) Open
DTC B0064, B0065, or B0066 Left Front/Driver Frontal Deployment Loop (Stage 2) Open
DTC B0077, B0078, B0079, B0080, B0081, or B0082 Left Front/Driver Frontal Deployment Loop (Stage 2) Open
DTC B0100, B0101, or B0102 Electronic Front End Sensor 1 Performance
DTC B0109, B0110, or B0111 Incorrect Electronic Front End Sensor 1 Installed
DTC B0112, B0113, or B0114 Incorrect Electronic Front End Sensor 1 Installed
DTC B0159 Outside Air Temperature Sensor Circuit Range/Performance
DTC B0164 Passenger Compartment Temperature Sensor #1 Circuit Range/Performance
DTC B0174 Output Air Temperature Sensor #1 Circuit Range/Performance
DTC B0179 Output Air Temperature Sensor #2 Circuit Range/Performance
DTC B0184 or B0189 Incorrect Electronic Front End Sensor 1 Installed
DTC B0248 Mode Door Inoperative Error
DTC B0249 Heater/Defrost/AC Door Range Error
DTC B0268 A/I Door Inoperative Error
DTC B0269 Air Inlet Door Range Error
DTC B0408 Temperature Control #1 (Main/Front) Circuit Malfunction
DTC B0409 Air Mix Door #1 Range Error
DTC B0419 Air Mix Door #2 Range Error
DTC B0423 Air Mix Door #2 Inoperative Error
DTC B0428 Air Mix Door #3 Inoperative Error
DTC B0429 Temperature Control #3 Rear Circuit Range/Performance
DTC B0510 RH Panel Discharge Temp Sensor Failure
DTC B0515 RH Heater Discharge Temp Sensor Failure
DTC B0520 Rear Discharge Temp Sensor Failure
DTC B1000 ECU Malfunction
DTC B1001 Option Configuration Error
DTC B1004 Keep Alive Memory (KAM)
DTC B1007 EEPROM Write Error
DTC Descriptor
DTC B1009 EEPROM Checksum Error
DTC B1013 ROM Checksum Error
DTC B1014 Program ROM Checksum Error
DTC B1259 Solar Load Sensor Circuit
DTC B1271 Theft Lock Enabled
DTC B1327 Device Power Circuit Low
DTC B1328 Device Power Circuit High
DTC B1390 Battery Voltage Sense Failure
DTC B1396 Device Voltage Reference Output 1 Circuit Range Performance
DTC B1420 Seat Switch Input Status
DTC B1422 Device Power Moding Malfunction
DTC B1438 IPC High Voltage Output Overcurrent to IPM
DTC B1513 Charging System Volts Low
DTC B1514 Charging System Volts High
DTC B1556 IPC EEPROM Odo/Configuration Error
DTC B1586 Mirror Horiz. Pos Sensor-Out of Range/Open
DTC B1591 Mirror Vert. Pos Sensor-Out of Range/Open
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1697, B1702, B1707, or B1712 EPROM Read Write Error
DTC B1717 Mirror Power Fold Control Switch Shorted Low
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, or B1820 Power Seat Switch Circuit
DTC B1825, B1850, B2355, B2365, or B2375 Power Seat Position Sensor Circuit
DTC B1830, B1835, B1840 or B1845 Power Seat Sensor Circuit Range Performance
DTC B1860 Driver Lumbar Vert Sensor CKT Malf
DTC B1870 Driver Belt Tower Up Switch Circuit Malfunction
DTC B1875 Driver Belt Tower Down Switch Circuit Malfunction
DTC B1900 Driver Belt Tower Vertical Sensor Malfunction
DTC B1913 or B1918 Power Seat Sensor Circuit Range Performance
DTC B2455 Power Seat Sensor Circuit Range Performance
DTC B2460 Navigation Antenna Selector Circuit High Current
DTC B2462 GPS Signal Error
DTC B2463 Navigation CD Player - No Disk
DTC B2464 Navigation CD Player - Decoding Error
DTC B2465 Navigation CD Player - Data Error
DTC B2466 Navigation VICS Memory Error
DTC B2468 Navigation Display Head (NDH) Malfunction
DTC B2470 Power Seat Sensor Circuit Range Performance
DTC B2474 Navigation Display Head (NDH) Back Lighting Malfunction
DTC B2475 Navigation Display Head (NDH) Auxiliary Input Malfunction
DTC B2476 Cellular Phone Select Service Switch Malfunction
DTC B2482 Cellular Phone Select Service Switch Range/Performance
DTC B2483 or B2484 Global Positioning System (GPS) Antenna Circuit
DTC B2556 Interior Lamp Rheostat Circuit Range
DTC B2641 Delayed Exterior Lighting Ctrl CKT Range
DTC B2646 Ambient Light Sensor Circuit Range
DTC B2734 Coded Key Controller Memory Failure
DTC B2757, B2762, B2767, or B2772 Memory Switch Circuit
DTC B2805 Steering Whl Controls HVAC Sw CKT Malf
DTC B2810 Steering Whl Ctrl Entertainment CKT Malf
DTC B2853, B2858, B2873, or B2878 Tilt/Telescoping Switch Circuit
DTC B2860 Telescope Position Sensor Range
DTC B2862 Telescope Position Sensor Low
DTC B2880 Tilt Position Sensor Range
DTC B2882 Tilt Position Sensor Low
DTC B2891 Tilt/Telescope Motor Over Current
DTC B2904 Tilt/Telescope 4-way Position Switch Circuit Malfunction
DTC B2960 Invalid Coded Key Present
DTC B3031 Key Decoder Device in Assem Learn Mode
DTC B3055 Key Not Present
DTC B3064 or B3069 Driver Door Key Cylinder Circuit
DTC B3109 Keyless Entry Transmitter Low Battery
DTC B3142, B3147, B3152, or B3157 Door Lock Switch Circuit
DTC B3172, B3177, B3182, B3187, B3192, B3197, B3282, B3287, or B3292 Window Switch Circuit
DTC B3377, B3382, B3387, B3392, B3397, B3452, B3457, B3462, B3467, B3472, B3477, B3482, B3517, or B3522 Master Window Switch Circuit
DTC B3527 Window Lockout Switch Circuit Low
DTC B3793 Memory Seat Module Over Current
DTC B3832 or B3833 Window Position Sensor Circuit
Brake Systems -ebcm
DTC C0550 ECU Malfunction
DTC C0563 Calibration ROM Checksum Error
DTC C0577, C0578, C0579, C0582, C0583, C0584, C0587, C0588, C0589, C0592, C0593 or C0594 Suspension Solenoid Circuit
DTC C0615, C0620, C0625 or C0630 Suspension Position Sensor Circuit
DTC C0625 Left Rear Position Sensor Malfunction
DTC C0628 Level Control Position Sensor Circuit High
DTC C0635, C0638, C0640, C0643, C1252, or C1253 Normal Force Circuit
DTC C0655 Level Control Compressor Relay Malfunction
DTC C0657 or C0658 Level Control Compressor Circuit
DTC C0658 Level Control Compressor Circuit High
DTC C0660 Level Control Exhaust Valve Circuit Malfunction
DTC C0662 or C0663 Level Control Exhaust Value Circuit
DTC C0663 Level Control Exhaust Valve Circuit High
DTC C0665 Chassis Pitch Signal Circuit
DTC C0690, C0691, or C0693 Damper Control Relay Circuit
DTC C0696 Position Sensor Overcurrent (5 volt supply)
DTC C0710 Steering Position Signal Malfunction
DTC C0750, C0755, C0760, or C0765 Tire Pressure Sensor Circuit
DTC C0896 Device Voltage Range/Performance
DTC C1211 ABS Indicator Lamp Circuit Malfunction
DTC C1214 System Relay Contact or Coil Circuit Open
DTC C1217 Pump Motor Shorted to Ground
DTC C1218 Pump Motor Circuit Shorted to Voltage or Motor Ground Open
DTC C1221-C1235 Wheel Speed Sensor Circuit
DTC C1236 Low System Supply Voltage
DTC C1237 High System Supply Voltage
DTC C1238 Brake Thermal Model Exceeded
DTC C1241 Variable Effort Steering Circuit Malfunction
DTC C1242 or C1243 Pump Motor Circuit
DTC C1248 EBCM Turned the Red Brake Warning Indicator On
DTC C1251 RSS Indicated Malfunction
DTC C1254 Abnormal Shutdown Detected
DTC C1255 or C1256 ECU Malfunction
DTC C1261-C1274 EBCM Internal Solenoid Circuit
DTC C1276, P1644, or P1689 Delivered Torque Circuit
DTC C1277 or P1571 Powertrain Indicated Traction Control Malfunction
DTC C1278 TCS Temporarily Inhibited By PCM
DTC C1281, C1283, or C1286 VSES Sensors Uncorrected
DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction
DTC C1284 or C1285 Lateral Accelerometer Circuit
DTC C1287 or C1288 Steering Position Sensor Circuit
DTC C1291 or C1293 Brake Switch Circuit
DTC C1294 Brake Lamp Switch Circuit Always Active
DTC C1295 Brake Lamp Switch Circuit Open
Power Control Module----pcm/ecm
DTC P0030 HO2S Heater Control Circuit Bank 1 Sensor 1
DTC P0036 HO2S Heater Control Circuit Bank 1 Sensor 2
DTC P0101 Mass Air Flow (MAF) Sensor Performance
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0106 Manifold Absolute Pressure (MAP) System Performance
DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0116 Engine Coolant Temperature (ECT) Sensor Performance
DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0121 TP Sensor Circuit Insufficient Activity
DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
DTC P0130 or P0150 HO2S Circuit
DTC P0131 or P0151 HO2S Circuit Low Voltage
DTC P0132 or P0152 HO2S Circuit High Voltage
DTC P0133 HO2S Slow Response Bank 1 Sensor 1
DTC P0134 or P0154 HO2S Circuit Insufficient Activity
DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
DTC P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
DTC P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
DTC P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
DTC P0141 HO2S Heater Performance Bank 1 Sensor 2
DTC P0153 HO2S Slow Response Bank 2 Sensor 1
DTC P0155 HO2S Heater Performance Bank 2 Sensor 1
DTC P0171 or P0174 Fuel Trim System Lean
DTC P0172 or P0175 Fuel Trim System Rich
DTC P0201-P0208 Injector Control Circuit
DTC P0218 Transmission Fluid Overtemperature
DTC P0230 Fuel Pump Relay Control Circuit
DTC P0300 Engine Misfire Detected
DTC P0325 PCM Knock Sensor Circuit
DTC P0326 Knock Sensor CKT Excessive Spark Retard
DTC P0327 Knock Sensor Circuit Low Voltage
DTC P0335 CKP Sensor A Circuit Performance
DTC P0336 Crankshaft Position (CKP) Sensor A Performance
DTC P0340 Camshaft Position (CMP) Sensor Circuit
DTC P0341 Camshaft Position (CMP) Sensor Performance
DTC P0351-P0358 Ignition Coil Control Circuit
DTC P0385 Crankshaft Position (CKP) Sensor B Circuit
DTC P0386 Crankshaft Position (CKP) Sensor B Performance
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0410 Secondary Air Injection (AIR) System
DTC P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1
DTC P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1
DTC P0420 Catalyst System Low Efficiency
DTC P0440 Evaporative Emission (EVAP) System
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443 EVAP Purge Solenoid Valve 1 Control CKT
DTC P0446 EVAP Vent Solenoid Valve Control System
DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0461 Fuel Level Sensor Performance
DTC P0462 Fuel Level Sensor Circuit Low Voltage
DTC P0463 Fuel Level Sensor Circuit High Voltage
DTC P0480 Cooling Fan Relay 1 Control Circuit
DTC P0481 Cooling Fan Relay 2 Control Circuit
DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0506 Idle Speed Low
DTC P0507 Idle Speed High
DTC P0532 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
DTC P0533 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
DTC P0560 System Voltage
DTC P0562 System Voltage Low
DTC P0563 System Voltage High
DTC P0574 Vehicle Speed Too High - Cruise Control Disabled
DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, or P1683 ECU Malfunction
DTC P0615 Starter Relay Control Circuit
DTC P0621 Generator L-Terminal Circuit
DTC P0622 Generator F-Terminal Circuit
DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit
DTC P0711 TFT Sensor Circuit Range/Performance
DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0716 Input Speed Sensor Circuit Intermittent
DTC P0717 Input Speed Sensor Circuit Low Input
DTC P0719 Brake Switch Circuit Low Input
DTC P0724 Brake Switch Circuit High Input
DTC P0731 Incorrect 1st Gear Ratio
DTC P0732 Incorrect 2nd Gear Ratio
DTC P0733 Incorrect 3rd Gear Ratio
DTC P0734 Incorrect 4th Gear Ratio
DTC P0741 TCC System Stuck Off
DTC P0742 TCC System Stuck On
DTC P0748 Pressure Control Solenoid Circuit Electrical
DTC P0751 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear
DTC P0752 1-2 Shift Solenoid Valve Performance - No Second or Third Gear
DTC P0756 2-3 Shift Solenoid Valve Performance - No First or Second Gear
DTC P0757 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
DTC P1031 HO2S Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
DTC P1032 HO2S Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
DTC P1133 or P1153 HO2S Insufficient Switching
DTC P1134 or P1154 HO2S Transition Time Ratio
DTC P1189 Engine Oil Pressure (EOP) Switch Circuit
DTC P1258 Engine Coolant Overtemperature - Protection Mode Active
DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
DTC P1359 Ignition Coil Group 1 Control Circuit
DTC P1360 Ignition Coil Group 2 Control Circuit
DTC P1372 Crankshaft Position (CKP) Sensor A-B Correlation
DTC P1380 Misfire Detected - Rough Road Data Not Available
DTC P1381 Misfire Detected - No Communication with Brake Control Module
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P1415 or P1416 Secondary Air Injection (AIR) System
DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P1531 A/C Temperature Sensor Circuit Malf
DTC P1536 Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
DTC P1540 Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
DTC P1545 Air Conditioning (A/C) Clutch Relay Control Circuit
DTC P1554 Cruise Control Feedback Circuit
DTC P1560 Transaxle Not in Drive - Cruise Control Disabled
DTC P1564 Vehicle Acceleration Too High - Cruise Control Disabled
DTC P1566 Engine RPM Too High - Cruise Control Disabled
DTC P1567 Active Banking Control Active - Cruise Control Disabled
DTC P1570 Traction Control Active - Cruise Control Disabled
DTC P1574 Stoplamp Switch Circuit
DTC P1575 Extended Travel Brake Switch Circuit
DTC P1585 Cruise Control Inhibit Output Circuit
DTC P1617 Engine Oil Level Switch Circuit
DTC P1624 Customer Snapshot Requested - Data Available
DTC P1630 Theft Deterrent Learn Mode Active
DTC P1631 Theft Deterrent Start Enable Signal Not Correct
DTC P1633 Ignition 0 Switch Circuit
DTC P1634 Ignition 1 Switch Circuit
DTC P1635 5 Volt Reference 1 Circuit
DTC P1639 5 Volt Reference 2 Circuit
DTC P1811 Maximum Adapt and Long Shift
DTC P1814 Torque Converter Overstressed
DTC P1820 Internal Mode Switch Circuit A Low
DTC P1822 Internal Mode Switch Circuit B High
DTC P1823 Internal Mode Switch Circuit P Low
DTC P1825 Internal Mode Switch - Invalid Range
DTC P1842 1-2 Shift Solenoid Circuit Low Voltage
DTC P1843 1-2 Shift Solenoid Circuit High Voltage
DTC P1845 2-3 Shift Solenoid Circuit Low Voltage
DTC P1847 2-3 Shift Solenoid Circuit High Voltage
DTC P1860 TCC PWM Solenoid Circuit Electrical
DTC P1868 Transmission Fluid Life
Basically No Communication
DTC U1000 and U1255 Class 2 Communication Malfunction
DTC U1001-U1254 Lost Communications With XXX
DTC U1300, U1301, or U1305 Class 2 Data Link Shorted
DTC U1713 or U1715 Loss of Front Door Module to Window Motor High Speed Comm.
DTC U1714 or U1716 Loss of Front Door Module to Window Motor Normal Speed Comm.
DTC U2153 VICS ECU Communication Error
b0408, cadillac, circuit, control, cts, deployment, deville, frontal, frontdriver, left, loop, malfunction, p0130, p0150, p0327, p0756, temperature
