Crankshaft sensors Where are they???
Old 03-06-2007, 12:45 PM
beach9618's Avatar
Default Crankshaft sensors Where are they???
I recently took my 2001 Eldorado ESC to the dealer and he found these 2 DTC codes:
1) P0135-02 Heater circuit B1-S1. Recommend replacing
2) P0385. Crank sensor circuit B. Recommend replacing both.
Does anyone out there have a picture from a Cadillac service manual that might show me where these items are located? I tried the library but no luck.
Thanks in advance
Jim
Old 03-09-2007, 01:42 AM
Katzmans Caddy's Avatar
Default RE: Crankshaft sensors Where are they???
This link may help you.
http://www.aa1car.com/library/2002/us100232.htm
Old 03-09-2007, 03:00 PM
beach9618's Avatar
Thanks for the info but unfortunately the pics don't show much.
Jim
Old 03-09-2007, 11:05 PM
So on the front of the engine is a big spocket, you can see it in the picture. The chains go from it to the camshafts on the head. The crank sensor is down where that big spocket is. On the real engine the spocket and chains have covers over them but it is down there where the crankshaft is. There is a black arrow on the picture.
Old 03-12-2007, 11:37 PM
beach9618's Avatar
Thanks again for the reply. Are you saying that the sensors are under thecrank sprocket cover? Without removing the cover I have looked extensively in the crank end of the engine andcan findno crank sensors. My engine is a 2001 and this picture relates to a 93-99. Could it be that they are located somewhere else on the the later engines? Also I can't see any black arrow in the picture.
Thanks again,
Jim
Old 03-12-2007, 11:43 PM
The N* was redesigned slightly for 2000. The sensor is on the spocket as far as I know. Let's do some more digging.
Old 03-13-2007, 07:00 PM
FLCaddytech's Avatar
Cranksenorsare in the middle of the engine block on any N*
Front of the car behind the front motor mount from underneth.
When you find the oil filter, look up and to the right. 2 plugs one over the other.
A 10mm bolt holds each in.
The redesigned sensors will be black and grey.
The black one goes on the bottom.
Old 03-13-2007, 08:45 PM
beach9618's Avatar
Thanks FLCADDYTECH
The sensors have been located and are being replaced as I type (I'm having my brother-in-law do it). So thanks again and thanks to Katzmans Caddy for the help as well.
Jim
Old 02-10-2017, 10:26 AM
Lance Boss's Avatar
I have a 2007 cadillac DTS and im trying to find the crankshaft sensor on the motor.... Can anybody help with this?
Old 02-10-2017, 10:29 AM
Lance Boss's Avatar
Its not located in that spot on my 2007 Cadillac dts
Quick Reply: Crankshaft sensors Where are they???
