Coolant overflow tank
I got the "Check Coolant Level" message today on my '00 deville. It's corroded between the overflow tank and the metal piece where my fill cap screws on and is leaking. Looks like I need a new tank. I found the part ( I think) on GMpartsdirect for $63. Can any techs tell me if what I'm looking for is the "Radiator Recovery Tank", and it's part #?
Any help is appriciated.
RE: Coolant overflow tank
yeah radiator recovery tank, coolant recovery tank, overflow tank
Coolant Recovery Kit;Will require surge tank outlet hose 25748907 & fitting 15151875, if;quick connect fitting isnt present at surge tank outlet; Years: 2000-2005
MOVED your post from sights and sounds to Gen Tech, more tech guys for you in this arena. Good luck.
Why not save 63 bucks and try cleaning up the rust, dremel tool with wire wheel or even some 180 grit, then spray paint it. Stuff a rag in the opening to keep ourtdebris. Get a new "radiator recovery tank" cap. Just my suggestion.
I proably didn't explain it well. The metal "Flange" (part of the tank) that the cap screws onto seen here:
Broke loose like this:
Also, you may notice a hole in the piece that broke off. A metal fitting with a piece of rubber hose was connected here. Is this the surge tank outlet hose and fitting?
Thanks for your help!
Thanks again. I wanted to make sure I got the right parts since it takes so long to get em. Also, do you think now would be a good time to do a flush? I have heard the dexcool antifreeze is somewhat corrosive and should be flushed every few years. It just turned 70k.
cady97dev
Aluminum Block V8s
03-20-2009 08:10 AM
wpbrink
07-25-2008 10:49 PM
