Coolant Additive / Bars Stop Leak - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 04-08-2009, 09:06 PM
Default Coolant Additive / Bars Stop Leak
The cadillac 4.1, 4.5, and 4.9 engines call for the GM tabs. Is this also true for the Northstar?
I am interested to know if these tabs are prone to restricting heatercore flow. I did a coolant system flush last year and added the tabs. My 4.5 cadillac heat warms up the car but doesn't get piping hot like the newer cars. In the winter I run the heat at 90 degrees max setting to stay warm, never having to move the temp down. Do these cars just don't produce heat that's piping hot?
Is it a common thing to have to reverse flush the heatercores on these motors?
Old 11-05-2009, 08:30 AM
1. yes
2. maybe, if not used properly
3. maybe if #2 applies
fuel additive mjdevo31 Cadillac Allante 1987 to 1992 Phase I & II 4 10-04-2014 12:40 AM
To use differential fluid additive or not? td25 General Tech 3 03-24-2011 04:24 PM
99 Deville Engine Oil Leaking - Stop Leak Treatments gigantor Cadillac Deville 13 03-10-2011 12:11 AM
Coolant Smell no Visible coolant or coolant in oil???? cady97dev Aluminum Block V8s 2 03-20-2009 08:10 AM
Stop leak? 92_Daddylac Cadillac Deville 6 03-31-2007 06:43 PM
Tags
additive, additivesbars, bars, cadillac, change, coolant, cooling, flush, gm, leak, northstar, radiator, reverse, stop, xlr
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
