Codes help for 95 Deville
Not sure where to post this, but could someone tell me what these codes mean? I ran a diagnostic and these came up-
P013 History
P044 History
P0052 History
I027 History
I039 History
I052 History
A047 Current
No SIR Codes
No TCS Codes
PCM?
Any help appreciated.
P013 History
P044 History
P0052 History
I027 History
I039 History
I052 History
A047 Current
No SIR Codes
No TCS Codes
PCM?
P013 O2 Sensor not ready
P044 Lean Exhaust
P052 ECM reset - Battery disconnected normal cause
I027 are you sure it not I037 - ACP data - A047 - cause it.
I039 Speed Sensitive Suspension - SSS code set - will not display through On-Board. They are flash codes at the SSS module, located in trunk on seat back electrical center behind trim panel.
I052 IPC reset - loss of 12v - Disconnected battery
A047 - low freon - check for leak
P044 Lean Exhaust
mrcrx28
03-13-2008 05:32 PM
jakemoore83
07-23-2007 11:59 AM
