charge problem with a 90 bro
Hi I'm a first time user so if I mess this up sorry in advance. I have a 1990 Cadillac Fleetwood Brougham. I've put a new alternator new battery new bulb in the charge indicater. The climate control is not dose not turn on. Alternator is not charging battery.
Not charging - with key on and 2 wire connector unplugged is there 12 volts at both terminals along with output terminal wire. The red wires should have voltage all the time. Brown wire at connector gets 12 from gauges fuse when key is on. If all three have 12v; take alternator back and have it tested.
Climate control - does it light up? if not check fuses. if it does add more info about what works and what doesn't
thank you
