Sponsored by:
Sponsored by:
Can you pull lock cylinder w/o key?
Old 08-19-2009, 06:13 PM
llwta76's Avatar
Default Can you pull lock cylinder w/o key?
On my 88 Eldorado can I pull the lock cylinder from the column w/o the key? It's jammed and I need to replace it . Any help would be gratefully appreciated! Larry
Old 08-19-2009, 06:21 PM
Yes. It really not much different than have key, you will need VATS key code to get correct blank.
Old 08-19-2009, 08:34 PM
llwta76's Avatar
Slowroll: Actually I do have the original key but it's so very badly worn that it no longer comes out of lock . I have all the guts out of the column but I can't get the key to put the cylinder to accessory mode to pull the cyl. per the service manual.(I can't seem to get the key code for my 1988 neither...too old). Thanks! Larry
PS:I don't have a VATS key just the old style ign. key
Old 08-20-2009, 01:17 AM
you dont have a spare key?
some advice for the rest .. have one made and place with the car's title. its a whole lot cheaper to pay $15 for a tucked-away key than to deal with a replacement of a cylinder or worst. In fact, AAA will make a FREE credit card key (no VATS) that can be used to make a real key or even to start the car.
the 1989 Allante had the 1st VATS, when did the rest of the Cadillac line followed?
Old 08-20-2009, 06:05 AM
llwta76's Avatar
Stealth: I don't have a spare key and the key I do have is so-o-o worn that there is virtually no teeth on the business end! Made a copy of it ...doesn't work. As posted earlier I am trying to get the lock cylinder out. So far I can't. Thanks! larry
Old 08-20-2009, 09:18 AM
here is a cheaper solution .. call a locksmith .. they can and will make a key to fit. somehow, they can get a blank into the cylinder and tag it with the lock tumblers in the cylinder, then cut the key.
if you got AAA, they will cover the 1st $100 or so.
I had one done, cost was $150.
culltwojc
10-19-2008 05:36 PM
bighank
11-22-2007 09:14 AM
wpbrink
08-02-2007 10:45 AM
Quick Reply: Can you pull lock cylinder w/o key?
