Sponsored by:
Sponsored by:
ALTERNATOR - BAD?????
Old 08-07-2006, 05:51 PM
EW1027's Avatar
Default ALTERNATOR - BAD?????
I was driving in stopped traffic at night when car died and would not start. knew it was electrical, but had no way of charging battery. Jumped car the next day (during daylight)and the car was driven home 20 miles with no problems. Took car to Autozone to have battery/alternator checked out. They said battery was good but the alternator was bad. My question is, I'm showing anywhere from 13.2 to 13.9 amps on the computer info while car is running with a/c full blast and lights. Is alternator really bad!!!!!. Seems as long as I'm above 12v I should be ok. Anyone know for sure - Thanks
Old 08-07-2006, 06:31 PM
FLCaddytech's Avatar
Default RE: ALTERNATOR - BAD?????
13.2 to 13.9 volts is correct, but it could have a bad diode and still produce good voltage.
Still i would get it tested somewhere else before purchasing an alternator.
Also check your cables for corrosion.
If you have any further questions please include year, make and model.
Old 08-08-2006, 12:35 AM
EW1027's Avatar
Thanks - FLCADDYTECH - Battery was tested and was bad. Obviously. battery wasn't holding the charge. One more question. If voltage drops below 13 is Alternator still having problems? or does voltage drop into the 12.s when everything is on.
astrodan13
Aluminum Block V8s
06-14-2011 12:24 AM
wpbrink
06-30-2008 09:15 AM
03-03-2008 10:14 PM
ajax68960
01-18-2008 06:25 PM
mrmadhead
09-04-2007 04:31 PM
Quick Reply: ALTERNATOR - BAD?????
