Alarm on a 91 seville - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 11-29-2009, 09:51 AM
Rzr's Avatar
Rzr Rzr is offline
Default Alarm on a 91 seville
hey there, anyone know how to either tone down the senstivity of the alarm on a 91 seville or just straight up disable it? the alarm itself will go off at loud noises and even if a bird poops on the car. And with me working at an airport, that means my alarm goes off every day which means its just draining my battery.
Anyone know how to turn that sensitivity down or off? also on a side note anyone know what the reset combo is for the engine oil life display?
Old 12-01-2009, 02:10 PM
Not sure about the alarm, however I found this http://caddyinfo.com/oillifeindicator.htm on google that may help with the oil matenience reset.
Old 12-01-2009, 07:43 PM
If you don't use power locks or remote to lock doors - alarm will not be armed.
Old 12-03-2009, 04:36 PM
Rzr's Avatar
Rzr Rzr is offline
thanks for the site, did help with the oil
Yeah im aware that the normal door locks will not activate the alarm, however im looking for some method of disabling the alarms system or at the very least reducing its sensitivity... for instance i was working on my other car the other day, and suddenly the alarm on the seville went off, when i got up to look i noticed a bird had **** on the roof.... it is that sensative. every schematic i look up for relays and fuses show htat the alarm fuse is connected in with the ignition. thus remove the fuse and the car wont start.
Old 12-04-2009, 11:05 AM
if it is not activated that be the same as being disabled.
Old 12-05-2009, 07:56 PM
Does have stock alarm system ? I have no info on shock sensor being part of factory installed Content Theft Deterent for 91 models.
1998 cadillac deville Check gas cap alarm denver Member Introduction 2 08-31-2012 10:44 PM
Seville STS Alarm And Dash Electrical Gremlin lraguz Cadillac STS 0 05-02-2008 09:34 AM
viper alarm 791 install atltrill Cadillac Seville 0 08-31-2006 08:40 AM
Alarm jd3parker General Tech 1 06-13-2006 11:18 PM
hands free color 2way car alarm raj3whls Private For Sale/Trade Classifieds 0 08-21-2004 05:42 PM
Tags
1992, 91, 92, alarm, bypass, cadillac, disable, disconnect, door, forums, lock, relay, reset, sensitive, sensitivity, seville, system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
