Sponsored by:
Sponsored by:
'96 DeVille Won't Start
Old 02-02-2008, 02:16 AM
DocHemi's Avatar
Default '96 DeVille Won't Start
OK Someone Please HELP!!!!
My'96 Deville started about 11 months ago, everyso often it would not crank when you turn the key. I hear a few relays kick, and the fuel pump cycle, but no crank. Battery is good, and so are cables, and everything else works.
If I cycled the key on and off, it would start after a few tries, and then no problems for a week or so, sometimes longer.
No I havent driven the car in 4 months, and wanted to move it in the shop. UH OH...Now after allmost 200 key cycles, I can not get any crank at all. Battery is fully charged (it was on trickle charge while sitting).
I hope someone has an idea what the problem might be. All the relays seem to be fine, and the cycle when i turn to crank, but starter refuses to turn.
Old 02-02-2008, 07:38 AM
Default RE: '96 DeVille Won't Start
Check for codes. Could be bad starter - check for 12v at S terminal of starter with key in start position.
Old 02-02-2008, 02:08 PM
DocHemi's Avatar
No Codes...."S" terminal...This is a Northstar with an internal starter...Where would I find the "S" terminal?
I'm leaning more towards something with the key cylnder...is that a good chance? How do I check?
PS: No key will make it crank and we have 3 so I have ruled out a bad key or pellet.
Old 02-02-2008, 07:20 PM
Starter is under intake. Do you have any warning lights or messages on DIC?
Old 02-02-2008, 08:39 PM
DocHemi's Avatar
Yes I know Starter is under intake..I stated internal starter, and NO CODES, at least non concerning PCM or engine. Only A/C code
Old 02-02-2008, 08:49 PM
Is there 12v at S teminal of starter?
Old 02-02-2008, 08:54 PM
DocHemi's Avatar
Like I asked before....WHERE DO I FIND THE "S" terminal you speak of?
Old 02-02-2008, 09:13 PM
ON THE STARTER!
Old 02-02-2008, 09:24 PM
DocHemi's Avatar
ORIGINAL: slowroll
ON THE STARTER!
UH CORRECT ME IF I AM WRONG HERE....
but are you suggesting tearing of the intake and all other items associated with getting to the starter just to check the "S" terminal?
IMHO..I think there is a much better diagnostic then to tear the engine down in hopes there is a problem to be found...what your suggesting is kind of like telling someone to take off the head to see in inserts were ever put into the head bolt threads in the block.
Old 02-03-2008, 07:06 AM
You asked, I answered. You don't like the answer,Oh well. If looked at your car.You would have found jumper harness connector for starter, at front of rear cam cover. Buy a FSM.
Quick Reply: '96 DeVille Won't Start
