Sponsored by:
Sponsored by:
95 SLS Wiring Burning
Old 04-21-2007, 07:54 AM
devildog19's Avatar
Default 95 SLS Wiring Burning
Hi. I have a 1995 SLS. The other day I opened my trunk to grab something out, and noticed a funny smell. After looking around a little Ialso seen smoke! Well the smell was coming from some wires that were RED hot and melting the black cover. The melting starts in the wires leading into the fuse box in the trunk ( it may even start further into the car, i didnt go in that deep), then I looked around some more and seen a wire that goes up the trunk hinge had melted. Well now I have no right tailights, or driving lights up front. I had someone hit the brakes and the brake lights work. I checked all the fuses, and sure enough the right tailight fuse was blown. Well afterI replaced it, it still didnt turn them on, and the fuse didnt blow. Another problem that I believe this caused is my trunk pull-down motor will not shut off.. it will just keep going up and down until you close it, but it will shut off when you close the trunk. I have no idea what caused the wires to melt, but they arent doing it anymore even after replacing fuses. I do remeber a while back i had to replace a light socket and thought that was the problem, but i checked it out and it was fine, and when i replaced a license plate light the drivers side bulb was melted into the plastic socket. If someone could please help me out it would be greatly appreciated.
robotic_junky
10
05-09-2021 09:18 PM
heimer77
04-12-2007 04:32 PM
ron0716
04-02-2007 01:54 PM
peace707
10-29-2006 09:07 PM
dallykay
08-02-2005 02:20 AM
Quick Reply: 95 SLS Wiring Burning
