Sponsored by:
Sponsored by:
95 seville engine/trans problem
Old 10-17-2007, 11:28 AM
oarivera's Avatar
Default 95 seville engine/trans problem
95 Seville, 115,000 miles, northstar engine
When the engine is running and the transmission is in drive there is a slight bucking. If the trans is put in neutral the engine will run smoothly. This only happens when the car is at a standstill.
Anysuggestions why this is happening will be appreciated. Thank you.
Old 10-17-2007, 09:06 PM
Default RE: 95 seville engine/trans problem
Need more info. ses light on or off .I suggest to check plugs,wires, and coil towers. If you see anything that looks like rust , that's where your problem lies.If it doesn't have AC plugs I would put in it.Hope it helps
Old 10-18-2007, 08:52 AM
oarivera's Avatar
Thanks for the reply. I'll check on the SES light and the other things. I'll be back as soon as I have more info.
Thank you again.
rukkus
03-02-2011 06:23 PM
cadillac marvin
09-03-2009 10:35 PM
rbud87
Automatic Transmissions
07-25-2007 02:50 PM
l306x
06-03-2007 02:29 PM
edtherock
12-09-2005 03:04 AM
Quick Reply: 95 seville engine/trans problem
