Turn signals not working
OK, so my turn signals aren't working...the corner light comes on, but not the flashers in the front & rear, nor do I have a flashing green arrow on the dash. I tried changing the fuse already. The hazards work perfectly. What else could it be? I noticed that the problem happened gradually, seemed like when the turn signals when they were working towards the end would get stuck or skip a few blinks...very weird. Any help would be greatly appreciated before someone rear ends me! Thanks!
RE: Turn signals not working
what make and model of car?I found other thread 94 Eldo. It will be called Turn Signal Flasher Module it is located behind left side of dash, left of steering column, and near chime. Its square with 3 wire connector - orange, black, and purple wires.
You could do it yourself, panel and shield beneath steering column need to come off to access it. You should invest in manual(s) so you can minimize your oouuff's
