'67 water pump n water manifold
Hey guys,
Can anyone help me? I've been trying to install a new water pump on my '67 convertible deville with 429 ci. My problem is I can't get the water manifold on without leaks after the water pump is installed. Is there a trick to the O-ring and manifold-to-head gasket set up? should I put the water manifold onto the pump before I try to put it all together? What should I seal the O-ring with where it meets the pump? Any help will be greatly appreciated!
Thanx, Chris
Thanx, Chris
RE: '67 water pump n water manifold
i missed this one before. not sure why you would need TWO o-rings
but if it works so be it. maybe the O-Ring you were given was not fat enough
or the surfaces were not quite coming together for some reason?
an old trick from my B52 / F4 days is to use "bee's was" to hold things in place
while one does the assy in weird hard to access spots. I still carry a block of
the stuff along with my "safety wire pliers".
"IF it is good enough for a F4 Fanthom , it is good enough for any of my cars"
1967caddi
10-10-2019 07:31 AM
dgmelp@aol.com
Cadillac Allante 1993 Phase III & VJ4
09-19-2010 10:28 PM
Blake442
01-05-2010 08:41 PM
